Just wondering if there's a way I can test my flares won't leak before I fit the lines to the car permanently? being new to flaring and unsure of it still a bit I'd hate to fit them all and go to fill it up to find they leak
If they don't look terribly deformed, it will be just a matter of torquing them up a bit more if they leak.
Brake pipe flairs should look like the ones in the pictures below, if they dont just keep practicing untill they do.
![]() ![]() Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 20th September 2012 at 06:33 PM. |
Well my practice ones look ok. the hardest part seems to be getting perfectly straight on the pipe before starting to flare. When I look at mine from the side, they just look ever so slightly uneven (eg slightly higher on one side).
Are you cutting the pipe with a hacksaw or using the pipe roller cutters ?
I've been using a dremel as I found it hard to cut with the rollers as it would end up crushing the end.
Just a few of things really, the pipe has to be cut square on the ends, debur the inside of the pipe and file a small chamfer on the outside of the pipe, if you use the roller cutters you only need to debur the inside of the pipe and dont bother with the chamfer outside, apply a drop of oil on the die before first op and all should be well. If this doesn`t work there has to be something wrong with the flair tool.
Nice thanks for the help Bob
