Old 13th September 2012, 09:33 PM
Default Tyre Size
I popped down to my local tyre centre today, but stumbled as i could not decide which size tyres to purchase.
I was looking at Toyo 195/50/R15 to replace the 195/60/R15 that is currently has. What is everyone else running for a good ride height?
Old 13th September 2012, 09:56 PM
Spike is the toyo the tyre of choice for the roadster ? So much in the way of rubber out there its hard to know whats best.
Old 13th September 2012, 10:09 PM
Its mainly the size I was interested in to get a decent ride height
Old 13th September 2012, 10:39 PM
I'm running 195/50R15 Toyos, and Sierra's speedo looks within limits (shows 70 km/h at 65 by GPS). The ride height is also fine, if I set the ride height to 11-12 cm everyone here recommends, the front lower wishbones are angled up a little bit (the wheel side is higher). Also note that with smaller tyres you get the gears shorter by several percent.
Old 13th September 2012, 10:45 PM
I think it's pretty well established that for track performance semi-slicks are best. Toyo Proxes R888, Advan A048, Avon has something similar, too. They have very soft rubber, meaty sidewalls, but are also driveable (carefully) in the wet. But they are noisy, bumpy, and wear fast. (Federal 595 RS-R are a good budget alternative if you can find it, I've heard).
Old 13th September 2012, 11:15 PM
DRCorsa DRCorsa is offline
Just to add to alga's contribution, i would like to note the DMACK's DMT-RC tyre which is a "brother" of the brand's rally tyres but with DOT and E marking certifications.
It comes in 4 compounds and the available sizes are here: http://www.vitalequipment.co.uk/inde...oduct_id=29830
If budget allows it i will get a set when i finish my car.
Old 23rd September 2012, 10:38 PM
there is 195/55r15 inbetween thoes 2 sizes and "track day" tyres are available in that size
no idea on tyres avialable or the price diffrence
Old 24th September 2012, 03:39 PM
To my way of thinking anything in a low profile usually gives a harsh ride given the fact that the sidewalls wont have a lot of give in them,its a trade of between handling and ride quality.
Change in profile height will also alter the rolling diameter,gear ratios and speedo reading.
Old 25th September 2012, 12:43 AM
well no 13 or 14inch options with our rear suspension setup
a 195/55r15 works out exactly same cir as the 185/65r14 on my doner
195/60r15 will have 3.3% bigger and 195/50r15 3.3% smaller if your worried about speedo readings
Old 25th September 2012, 01:43 PM
14 inch steelies fit, but only just.
