200hp zetecs cost between 3k and 5k if they are built properly, someone best phone up the tuning boys and tell them about mega sqiff . Keep going at it Wasa its the way to go. Shame these cars arn`t like the old range rover with a complete stand alone ecu and wiring system. All it did was pick up a couple of wires on its way past the ignition switch.Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 24th September 2012 at 04:50 PM. |
I allready do the Mondeo zetec ecu's silver and black top.
The mondeo engine loom is almost self contained. If you could fit it in the engine bay there would only be one 42 pin plug to wire up and only around half the plug is used. These are good for around 150bhp The st170 gets more advanced and more complicated. The extra tunning needs extra controle. On top of the blacktop stuff... you have. barametric sensor vairable inlet vairable valve timming returnless fuel pump controler and pressure sensors. pre and post o2 sensors. The ecu also hooks into all sorts inclueding the clock If I can do this then I can do the RS loom.
Nowt again. |
carbs just cant give you spot on fueling everywhere and std ecus are set by car makers and have to create somthing thats is designed to make an engine econimcal,quiet,smooth,enviromental and long lasting you can do some basic ajustment if you can get in, but are hardware limited.
any programable ecu is the door to running what ever you want or need plus everythin is ajustable to what you want at college we had a std n/a toyota twincam on a bench dyno with 4 gas ( widebands where very rare at the time) and loads of other monitor equipment with two ecu setups one std toyota ecu and hardware and the other was a early programable unit that was swaped over from the std toyota one all other hardware was unchanged the toyota ecu was programed by toyota and would retard ign in areas to reduce noise and run lean in other areas for enviromental regs etc when the programable unit was used set to optimum fueling and timing the torque plot was way higher at all rpms and had no holow points just one big nice arc. we used this bench dyno for all sorts of sudies on engine manigment and automotive eletronics i did not cover actual live dyno mapping just the effects of modern engine magement, live mapping was done by the motorsport enginering students but we did share lots of the same classes together in my 3rd year corse if anyone here actualy has anymore experince here than me im all ears also done some work with diesel engines on a realy old water brake dyno if anyone here knows them |
now if anyone has sorted a st170 motor with a programable ecu to run verible cam timing and snip out the cat and ditch all the rubish that would be intersting ![]() |
![]() ![]() Bob
wow that looks posher than the one i used we had to hang weights off the arm on side of it and ajust the vane angle to get it to ballance then had to work it all out on paper sadly that was the whole idea of the exersise more about number crunching. fun fun fun
god knows where thay dug it up from it was very old work sent me to our rail engine rebilders as a triaining exesise a few years back i got a look around all thair dynos as i showed some interst, thay had some real monsters there and had some cat 1200bhp lifeboat engines running full chat on one and some massive mtu units on the other was a real eye opener made everything else look tiny i only got to play on the dyno with engine we used and i help rebuild also dyno'ed a hyd gearbox for efficency that was basicly 2 torque meaters either side Last edited by baz-r : 25th September 2012 at 02:03 AM. Reason: extra info |
I was hopeing someone here was going to tell me how to drive the thing.I have never seen or used one of the water braked jobbies before
#18
Cosworth head on a Pinto is a BIG job
Pistons no cheap way out Cam belt crank pully, the cossy crank is longer and the pully smaller will need to machine to fit a Pinto crank I would question cost saving over an injected Zetec All interesting this thread, the Ford ECU whatever version is always difficult to break into, I have a friend who can using Ford software to get very deep into it but every instalation would need him at the rolling road. Megasquirt has been proven but I find it a leap to far for me, price though is competitive and we have picked them up under £200 There will always be a limit on how much you an squeeze out of a standard engine, the ST170 never made 170bhp. I watch with interest |
#19
I'll second that! About 4 positives, 2 negatives and it starts up. But its layout is such that you'd have to mount the ECU under the nose cone, not the best of places.
#20
you need to factor the loss of your waterbrake as some energy is converted to heat etc. also are well know for been inconsistent so be warned we took 6 or so runs to get an avrage or "mean" reading took all day to do then another full day number crunching here is a little run down on how we used it on a big diesel engine on wot to get max fueling on the govener we would add weights to end of arm then ajust vain angle to ajust brakes load and lift the weight the more weight it could lift before pulling rpms down the more torque you had , keep repeating adding vain angle and weight taking readings as we go untill we pull the rpms all the way down. then number crunch losses and all the other stuff to get accurate torque for each load point that then create dots on a graph then a good old bit of dot to dot to get a torque curve then do same again to get a bhp curve all was a bit back to front as you had to find what rpms you had for each torque 100nm then 110nm and so on not what torque was at set rpms i think later waterbrakes had hyd pressure cells i think everything is eletric now and has been for some time waterbrakes where very old hat 17years ago as i can remember |
