Old 3rd October 2012, 02:33 PM
Default xmas package offer
If you have been looking at building a roadster but you don't fancy making every thing and the cost of buying new has put you off then perhaps you might be interested in my pre Christmas offer?
I'm offering a standard book chassis,all 8 wishbones,full set of polybushes and rear upright package for £750 with instalments of £75 a week.
The chassis will be supplied in bare ERW 1.6 wall with your choice of either type9 or MT75 tunnel, all suspension brackets welded in place, steering column and rack mounts, lower seat belt mounts, 5mm engine mount plates and a choice of either a book spec rear tub frame or Saturn GRP tank frame.
The 8 wishbones will be 2mm ERW tube machine profiled and jig welded with the M20 adjusters tig welded. These will be supplied painted gloss black with the poly bushes fitted.
The rear fabricated uprights will be set at 30' so they will suit both disk and drum brakes these will also be supplied painted gloss black.
If any body is interested in taking me up on the offer please message me through here.
