Old 5th October 2012, 02:28 PM
Ahaha! My mum had one of them! Nice job, car loks good. You are a very productive person in more ways than one!
Old 7th October 2012, 10:24 PM
Thanks Chris!
Had to man up and get the real power tools out this weekend.
I've done a bit of grinding, drilling, and welding here and there, and whipped the jigsaw out to make a start on the dash:
Old 7th October 2012, 10:37 PM
Looking good skov. How are you changing the speedo drive from cable to electric? I like the instruments you have chosen.
Old 7th October 2012, 10:46 PM
Thanks David. I've replaced the speedo cable with a speed sensor from a Mk2 MX5:
[quote=skov;7837
(I tried knitting one for one of the babies a few years back. About six inches in I gave up as it looked more like the Indian subcontinent than a scarf!)[/QUOTE]
What Bradford??????
Are you getting any other guages?? glovebox etc.
Old 8th October 2012, 10:31 AM
Oooh, that's a bit politically incorrect
I'm planning to keep the dash nice and simple.
The only additional things I'm going to add are hazard and rear fog switches.
The clocks have all the tell-tale lights I need build into them, and they have a couple of little LCDs which I'm hoping I can use to display anything else I might want.
Old 8th October 2012, 10:52 AM
Sorry I meant to say Southall.
So if the clocks have all the lights in ie highbeam,oil,indicators and ignition they would meet the iva standards ????. Seems like the way to go, thats a lot of stuff not to have to mount.
Old 8th October 2012, 12:13 PM
They should meet IVA standards, they're all the right picograms and colours and presumably passed type approval in the mini, so hopefully I'll be ok!
The only thing it's missing is a rear fog tell-tale, but I'm hoping I can use a switch with that built in.
Old 16th October 2012, 11:44 PM
Numplumb Numplumb is offline
Hi skov just read your thread from start to finish, what a brilliant job so far.
I'm a new member I have just bought a part built chassis which I'm going to alter so as I can use an MX5 donor, been reading lots about it and would love to build one half as good as yours.
Keep up the good work Regards Mick.
Old 17th October 2012, 10:15 AM
You're too kind Mick!
Are you sure you haven't got me mixed up with someone else though
Good luck with the build.
