Old 11th October 2012, 09:33 PM
If your hell bent on a 4x4 roadster then you might want to look at an Impreza as it will be so much easier to make, I have the front end of a chassis already fabbed as I was going to do a flat four build. Just push the lump as far forward as you can get it and pull the front wishbones back a 100-150mm to keep the drive shaft angles some where near acceptable.
