  #34
Old 14th October 2012, 09:57 AM
I,ve used a sandwich plate to allow electrical oil pressure & oil temps senders to be fitted, tho I had a slight problem getting a reading at first.....the sandwich plate allows the fitting of 4 senders to be installed, I had my 2 senders fitted at the the lower part of the plate, I couldn,t understand why getting no readings, swapped the 2 senders & placed them into the upper part of the sandwich plate = problem solved...not sure why but it worked .
I,m running a 1.8 CVH engine
