Old 14th October 2012, 06:28 PM
They can be made to fit, just do a search.
Old 14th October 2012, 06:34 PM
shaun shaun is offline
thanks, will do.
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
Old 14th October 2012, 06:39 PM
big_wasa's Avatar
big_wasa big_wasa is offline
Happy to be proved wrong but I am sure it wont. The bearing caps are 20mm deeper on the silvertop.
Nowt again.
Old 14th October 2012, 06:43 PM
http://www.talkford.com/topic/131390...k/page__st__20
Old 14th October 2012, 06:52 PM
big_wasa's Avatar
Every day is a school day
When I offered one up it needed a bit more chopping than that.
Nowt again.
Old 14th October 2012, 07:11 PM
Sumpthing learned
Oh no not again
Old 14th October 2012, 07:15 PM
I think I will have a read, when I recieve it, I will go on tha assumption it will fit......
Old 14th October 2012, 09:56 PM
Big Vern Big Vern is offline
Indeed they are,
Silvertop sumps fit blacktop but not the other way round
Old 14th October 2012, 10:29 PM
The 1.8 CVH sump does not fit silvertops ideally, either. The rear crank seal arc has an about 4 mm gap, the front about 2 mm. The CVH gasket is thick in both arc sections. What I did cut down most of the gasket's width in the front crescent, so that the remaining strip compresses to the right thickness. Plus a liberal amount of silicone sealant.
