Old 19th October 2012, 04:22 PM
Trying to get space in the garage, sold my 2 V6 Type 9's which made some impact. But the 2 DOHC's, Zetec, 12V V6 and 24V V6, Spare 4pot type 9, 2 spare 4x4 MT75 and RWD MT75 are just the tip of the tidy up iceberg!!
my god and i thort i was a horder
im sure you can convert some of all that to build tokens
Old 21st October 2012, 05:34 PM
Have 2 out of the 4 bonnet latches on now. will need some minor finishing on final assembly but they make a big difference holding the lid in place
Old 22nd October 2012, 12:34 PM
Oooohh..
4 out of 4 bonet catches on. May need some fettling to get them tighter...
And I have started looking at the column bearing, need to bash out the old style mount. The new bearing has been tested in place and looks good.
Try and get a few pics later tonight has been a very long time since a decent shot has been taken.
Old 20th February 2013, 06:31 PM
Fired her up always sounds good even for a 1.8CVH
then bashed off the old column bearing mount, just need to grind down the old welds and then fit up the new bearing.
Sold a 2.0DOHC so there is a little more space to play with in the garage. It's just not very tidy.
Old 3rd March 2013, 08:33 AM
Column bearing is now in place, couple of little mits to tidy on it but it's going to be much better than the sierra item.
Then got distracted by firing up the 24V sierra.
And then set about removing the front suspension from the XR4x4 in order to get ready for removing that cars engine and starting the repair work on the shell. Cut out a long bit of rotten sill.
3 Projects, time share, slow progress.
Old 3rd March 2013, 08:41 AM
rpjg1975 rpjg1975 is offline
Getting there then slowly tt?
I'm on hold due to reroofing the garage but itching to get cracked on now its a bit warmer!
Old 3rd March 2013, 08:54 AM
Very Very Slowly.
Usual thing, get al the heavy big jobs done and then slow right down on the small things.
24V sierra is 12 Years Off road.
