Old 20th October 2012, 10:35 AM
Moved on to the sender/pump assembly yesterday ....it needed to be lengthened by around 6" twisted and angled to be able to put the filter sock into the surge tank so I cut the mounting frame in the middle and fabricated an aluminium extension piece to facilitate all of the above. the Walbro pump was a little slack when mounted so a clamp was altered to help make it a lot more solid
Here is a picture of it sitting as it would be if it were inside the tank.
Old 20th October 2012, 10:10 PM
Have decided to mount the tank on with rubber bobbin type mounts rather than the typical straps ....had some lying around so it seemed a shame not to use them
tank protectors made from rubber hose
upper tank mount (bobbin) tank bracket not welded on yet
lower tank mount
Old 21st October 2012, 01:19 AM
Old Jag Guy's Avatar
Old Jag Guy Old Jag Guy is offline
Good evening! Well, if I can use a U.K. saying..."spot on",Kev!! Your updates are always inspiring! How many gallon capacity is that? I have started my "build", and will be posting pictures soon. Don
Miss you Doug and Charlie!!
Old 21st October 2012, 11:57 AM
Hi Don...capacity is close to 12 uk gallons or around 54 litres.....it might be overkill but at least it will put some weight onto the back wheels when full and I won't be gauge watching and worrying where the next gas station is
Old 22nd October 2012, 01:42 AM
Well I managed to complete my fuel tank yesterday.....all that is left to do on that is test for leaks, so it will be out with the brush and soapy water today and a little compressed air.....mountings have all welded nice and accurate in terms of fitment and it is nice and solid, did not think it would take the time that it has to completely finish it.
I am hoping to get my propshaft over the next day or two so gearbox fitment will be the next order of the day which will give me time to work on clutch slave cylinder mounting (which is going to be tight)
here is a few pics of the completed tank
Fill pipe welded on complete with anti syphon shield inside
fill pipe and vent
pump sender assembly fitted
tank fitted but will remove for leak tests
Old 22nd October 2012, 07:49 AM
Kin brilliant. 12 gallons is not overkill because you have the choice to run it low for a track day if you want. Certainly on a run you will be grateful of the capacity. The only change I would make to the tank is baffles or explosafe.
bob
Old 22nd October 2012, 11:28 AM
bob
Bob....It does have a just off centre full size baffle but the explosafe foam/sponge would render the fuel gauge inoperable meaning I would have to use some kind of external clear pipe like an oil catch can.....can't be ar*ed to do that.
