Old 23rd October 2012, 09:52 AM
Are you planning on having it fitted before you get the car tested at IVA?
You will need to consider the following during it's construction
A:the screen needs to be kite marked to the relevant BS spec and the surround needs to meet the radious requirements. I've found a company that was approched by Caterham your looking at around £200.
B:the wind screen wipers and washer jets need to clear the screen properly and park out of the way. This can be done by cut'n'shut the linkages but you need to get this right.
C:you need to fit a demisting system either electric or a water matrix both will need fans. Most car systems are large look on ebay for very small units.
I've looked in to this with a view to supplying a complete bolt on kit and it's looking to cost around £500-700.
