Old 26th October 2012, 03:35 PM
what pully you need? little denso's are hard to find with pk4 (4 rib) pullys and up
Old 26th October 2012, 10:51 PM
I got one of those underdrive ali pulley sets so i can bore the alternator pulley to any size I like so that wont be a problem. http://i29.photobucket.com/albums/c2...m3/a111112.jpg.
Old 27th October 2012, 06:44 PM
Dualist's Avatar
Dualist Dualist is offline
Sorry for the lag in posting pics mate but here you go.....
Alternator of a RX7 13b.
Hope this of some use.
Old 28th October 2012, 10:17 PM
WFMB Baz someone is knocking them out on bay of thieves, stumbled across them looking at the denso alternators.They are five rib but that wont matter http://www.ebay.co.uk/itm/Ali-Altern...item4abd28a13d
Old 29th October 2012, 10:54 PM
i was after 6pk (6 grove) or 5 when i was looking for my own build and there was none about then also the smallest body denso's (>40A) usualy have 3pk or v belt as std fitments also the denso pully is a small bore so it was sleave and larger bore pully job
powervamp do them now as i just seen at exeter show
i ended up useing a larger birdcage (internal fan) alternator made by mitsubishi 70A with a bespoke mount
