![]() The longest MX5 diff you will find is a 3.6:1.
Your chosen bike engine will play a huge part in if your diff is long enough. I did consider a BEC using MX5 running gear and if you're using a fairly modern bike engine, then a 3.6:1 diff would be long enough (based on the gear ratio calculator I have). |
