Old 2nd November 2012, 10:14 AM
Originally Posted by flyerncle View Post
I tied mine to a car body jig to weld it and it still distorted very slightly.
Check your measurements and placement of the components and only when you are 100% sure weld it.
Once welded there is a lot of stress and tension on all parts and if you have to remake it guaranteed it will go twang when you cut into it.
If your base table is substantial try using 3 lengths of 25mm x 25mm tube, lay them across the base rails front middle and back and screw them down to your table. This will keep your chassis flat while you go through the standard welding procedure.
AndyH
