Old 4th November 2012, 02:21 PM
onedayTM onedayTM is offline
cheers for reply,
no its not fly by wire, its normal throttle cable auto choke with a carb like unit but with a central injection unit in from the top, it also has the following connected to it; fuel pressure regulator, intake air temp sender, throttle position sensor, throttle plate control motor. would you suggest taking unit off and giving good clean out, also where can I get fuelpressure gauge that can be fitted in line so i can check to see if getting right pressure.
thank
tony
