Old 5th November 2012, 10:06 PM
Tatey's Avatar
Tatey Tatey is offline
Thanks for the help, I have now knocked off the angled tube on the back of the pedal box for the clutch cable, removed the rubber bung/plastic cap and I just drilled out a M12 nyloc to 13mm which gives a really nice fit for the clutch cable so it will stay nice and straight when coming out of then pedal box, it will also mean it will run under the brake line so should give a nice tidy solution. I should have this completed in the next few days and then I can finish fitting my handbrake cable with the above advice.
