Old 7th November 2012, 12:00 PM
Originally Posted by robo View Post
All the graft you put in on the parts cleaning and paint has paid off kev it looks great
worst is yet to come Bob .....engine block and associated stuff
decided to to sort out handbrake for a change ......could not decide on slotting the cp plate or cutting cable, eventually decided to cut cable and join. I found a n easy way to join the cable back together, after a rummage in an odds and ends box I came across a buss bar contact from an old distribution board that had a nice handy tab on it where I could drill two holes in to slot the wire into once the two screws were tightened up.....picture might make more sense of it oh and it is not finished yet.
Old 7th November 2012, 12:35 PM
Got this back the other day after being checked and all journals polished
and also finding a set of Taiho bearings mains and big ends off the bay for £64 posted means I need to start the tear down of the engine. I was going to go for ACL race bearings but I found out that Taiho are OEM for some Nissan and Toyota engines
Old 7th November 2012, 06:36 PM
If I was you Kev I would knock out all the core plugs and take the whole lot down to the nearest recon shop and have them hot tank it bolts and all. Probably only charge you £25 . That gets rid of all the paint,all the oil sludge and descales the waterways. We got a bupi here and anthing mechanical goes into that. Not as big as this one but about a meter square http://www2.ppauctions.com/_assets/a...t_171_7859.jpg. Nooooooooooooooooooooooooo scrubbing
bob
Old 7th November 2012, 07:14 PM
I would do Bob, buuuuuut the guy I got it off told me he had the head reconned, skimmed, pressure tested. and so far on initial strip down it looks like he was genuine so rather than give me more work than needed I'm going to leave the head complete with cams fitted on the block and get to work with my dremmel and powerfile, so the only work I am to do will be change all the bottom end bearings and a new t belt.......teardown now underway
Old 7th November 2012, 11:46 PM
Having got all the ancillaries, plenum, fuel rail, injectors etc I was surprised to find the engines narrowest point was less than 6" anyway the block was subjected to a thorough wire brushing and with all holes blocked off the dremmel and powerfile came out to play
Old 8th November 2012, 09:54 AM
got a bit more done so halfway through this side, its a orrible manky job but it will look nicer when painted.
Old 8th November 2012, 11:54 AM
motomaniac motomaniac is offline
cant you use a drill with a wire brush attatchment?... various sizes available, would be quicker than a dremel...... even a flap wheel for the flatter stuff
