Old 27th November 2012, 07:03 AM
Wynand's Avatar
Wynand Wynand is offline
Originally Posted by robo View Post
One thing not touched on here is getting yourself comfy, I always try to position myself so my elbow is resting on somethng which helps steady the hand, Sounds silly but helps.
The first thing I taught my apprentices in welding class is to get in an absolute comfortable position for the weld even if it mean you have to sit down - do a test "dry" run to see if you have 100% control and always stays your welding hand with elbow or use other hand as a support to rest the weld hand on.
Wynand
http://5psi.net
