Old 28th November 2012, 08:18 PM
gaz05 gaz05 is offline
Tatey
I'm just looking at the brackets you've used for your front brake pipes. I'm holding off on mine until the side panels are on because I was under the impression that you can't have the flexi going through a hole in the side panel. I think the flexi bulhead fitting has to be on the side panel. I stand to be corrected though.
Originally Posted by Tatey View Post
Carl here are some pictures of how I have mounted my 1.8 silvertop:
Engine in place:
Engine mounts (Landrover V8):
Picture showing the left hand engine mount made from 5mm plate and 50mm box.
Total cost so far
Materials £3,150
Tools £855
