Old 18th December 2012, 06:28 PM
Joelove's Avatar
Joelove Joelove is offline
Originally Posted by Big Vern View Post
On page 38 total width 1118mm minus trans tunnel 178mm = 940 divide by 2 = 470mm. Simples
Dave Bolam has them fitted and they are used by others.
Ah but if you look the 1118 is to the outer edges so that's another -25mm either side!
Old 18th December 2012, 06:32 PM
Joelove's Avatar
Thanks peeps, these are the ones ill go for then, even the ones in the book look tight so ill stop worrying
Old 18th December 2012, 08:33 PM
Big Vern Big Vern is offline
If you look at the widest point of the seat and its position in the chassis then there are no tubes in the area boundered by TR3, U4, BR5 and D7 so you have the full width of the chassis all the way out to the inside of the ally skin that goes on the outside of the chassis sides - 1118mm
Further the seats are 445mm and the space in the chassis is 470mm
470mm - 445mm = 25mm So they fit even if the chassis tubes were in that area - Point!
As shown in Dave Bolams picture they fit and plenty of others have fitted them but if you are concerned then don't use them
BV
Old 18th December 2012, 08:38 PM
Joelove's Avatar
Talking
BV
I don't want to fit these seats anyway, I was just wondering
