Old 19th January 2013, 10:08 AM
The suspension will not move much more than 1-1.5" max when in use, if they hit the bump stops you'll need to up the spring rate. I assumed that the damper was fully open when you took the pic so those will be fine. Light cars tend to skip over bumps at speeds over 25-30mph rather than absorb them like softly sprung productions cars do.
