Old 10th February 2013, 08:10 AM
loony's Avatar
loony loony is offline
And now... should I fully weld it, or make rear suspension framework...
Chassis is bolted/welded to build table, so in my opinion it would be better to fully weld it now, then make rear framework, and in the end - weld suspension brackets...
Lucas
My build thread
Old 10th February 2013, 08:14 AM
loony's Avatar
I also made bucket's insert - for electrolysis cleaning (front calipers, maybe upright/hubs):
Lucas
My build thread
Old 16th February 2013, 08:02 PM
loony's Avatar
Another Saturday...
First, I got my Birthday present - mainly form myself, but my "other half" had her contribution in it. Now I'm ready to take care after all this nuts ;-)
I also picked up Fiat Cinquecento seats - bought some time age for... about £10. Naturally seats are too wide, but... I need only runners, which are very easy to modify (only one bar/tube). Universal runners alone cost more than this whole seats...
So, first task was to separate runners form seats...
Few minutes later...
Lucas
My build thread
Old 16th February 2013, 08:09 PM
loony's Avatar
On Thursday I picked upa GRP seats for "client". As my seats will be same but 50mm wider (these are 39cm wide so they are tight), I can plan where I need my runners.
I also made steering support frame...
Lucas
My build thread
Old 16th February 2013, 08:15 PM
loony's Avatar
Finally I couldn't resist to trial fit some components:
Because I didn't want to start something bigger - I prepared tubes and welded pedals...
Next I will fully weld chassis, before I move it forward to weld rear suspension frame...
Lucas
My build thread
Old 18th February 2013, 09:41 PM
loony's Avatar
Today I got my MKIndy inspired laser cut rear uprights:
And... my first SolidWorks finished project - seat mounting plate:
Lucas
My build thread
Old 19th February 2013, 06:35 PM
Oscar Oscar is offline
Not sure if you've realised yet, but your chassis has a major design flaw...
Steering wheels on the wrong side
Looking great, especially like the rear upright design. Should be super strong!
Photos of the project so far:
Old 20th February 2013, 07:33 AM
loony's Avatar
Damn, I knew it's something wrong with this angles
I have spare steering column so I can weld second on the other side
Lucas
My build thread
Old 20th February 2013, 10:11 PM
loony's Avatar
Another small step to happiness:
I drill/cut holes for master cylinder...
And fit "custom" CP15 to steering column support:
Of course I have problem with clearance between steering column and TR9, so I will finish it when I get column bearing (maybe friday/saturday).
Lucas
My build thread
Old 27th February 2013, 07:18 AM
loony's Avatar
After long battle, yesterday I picked up column bearing... PFL205 housing + UC205 bearing:
Lucas
My build thread
