#31
![]() ![]() ![]() ![]() ![]() And now... should I fully weld it, or make rear suspension framework... Chassis is bolted/welded to build table, so in my opinion it would be better to fully weld it now, then make rear framework, and in the end - weld suspension brackets...
Lucas ZX9R BEC Haynes Roadster - build cost so far: £1125 My build thread "Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe Last edited by loony : 10th February 2013 at 08:20 AM. |
#32
![]() I also made bucket's insert - for electrolysis cleaning (front calipers, maybe upright/hubs):
Lucas ZX9R BEC Haynes Roadster - build cost so far: £1125 My build thread "Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe |
#33
![]() Another Saturday...
First, I got my Birthday present - mainly form myself, but my "other half" had her contribution in it. Now I'm ready to take care after all this nuts ;-) ![]() I also picked up Fiat Cinquecento seats - bought some time age for... about £10. Naturally seats are too wide, but... I need only runners, which are very easy to modify (only one bar/tube). Universal runners alone cost more than this whole seats... ![]() So, first task was to separate runners form seats... ![]() Few minutes later... ![]()
#34
![]() On Thursday I picked upa GRP seats for "client". As my seats will be same but 50mm wider (these are 39cm wide so they are tight), I can plan where I need my runners.
![]() ![]() ![]() I also made steering support frame... ![]()
#35
![]() Finally I couldn't resist to trial fit some components:
![]() ![]() Because I didn't want to start something bigger - I prepared tubes and welded pedals... ![]() Next I will fully weld chassis, before I move it forward to weld rear suspension frame...
#36
![]() Today I got my MKIndy inspired laser cut rear uprights:
![]() ![]() And... my first SolidWorks finished project - seat mounting plate: ![]()
Lucas ZX9R BEC Haynes Roadster - build cost so far: £1125 My build thread "Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe Last edited by loony : 19th February 2013 at 07:31 AM. |
#37
![]() Not sure if you've realised yet, but your chassis has a major design flaw...
Steering wheels on the wrong side ![]() ![]() Looking great, especially like the rear upright design. Should be super strong! |
#38
![]() Quote:
![]() I have spare steering column so I can weld second on the other side ![]()
#39
![]() Another small step to happiness:
I drill/cut holes for master cylinder... ![]() And fit "custom" CP15 to steering column support: ![]() ![]() ![]() Of course I have problem with clearance between steering column and TR9, so I will finish it when I get column bearing (maybe friday/saturday).
#40
![]() After long battle, yesterday I picked up column bearing... PFL205 housing + UC205 bearing:
