Old 24th February 2013, 10:34 PM
Default Fuel tank earth
I know there is an Iva requirement to earth the fuel tank however I am wondering if the earth lead from the internal pump/ sender unit will be sufficient. I am using he mx5 based sender this is earthed and bolted to the tank.
Any advice would be helpful.
Old 25th February 2013, 09:42 AM
Use a seperate lead from sender securing screws/bolts to chassis,remove paint and use star/spring washer.
