Old 27th February 2013, 10:22 AM
On page 159 of the book it has recommended starting points.
Front and Rear Camber 1 degree negative
Front Toe In 0-0.5 degrees
Type Pressures 18-20psi.
Old 27th February 2013, 10:27 AM
Thanks.
Why don't you get you logo made into a badge as it would look great on a nosecone.... or let me have the artwork to make some up.
Old 27th February 2013, 11:12 AM
Originally Posted by Davidbolam View Post
Thanks.
I have a CNC Mill at home to do just that. Wheel centres too.
If you want the artwork still I can sent it over.
Stot.
Old 27th February 2013, 06:13 PM
By all means do David,no probs at all.
Every time I am in the curcuit its usually mental with inbound IFR traffic and they tend to say the imortal words "keep it tight and expadite vacate" so I tend to turn base at Brunswick Ind Est and descend quick to land well up to vacate Foxtrot.
Set up a flashing light and we can sort a flight one day.
If you are stuck let me know.
Old 5th March 2013, 08:41 PM
Somewhere I have a bright orange allied forces marker (from the gulf war 1 designed for the top of a tank. not mine just acquired it) as long as you not in an a10 you should spot it.
Here is a picture of the earth bond I have added to my tank. I have used 17 amp wire. Will this be sufficiently thick?
Old 6th March 2013, 02:57 PM
Hi David,
Just modded the sender for my build to fit it into the tank. My first question is....
How have you bolted/bonded the pump and sender unit to the tank?
and secondly.....
Surely if you earth the tank to the body when fuel causes a path of least resistance between the tank and the live wire in the tank the pump and/or sender will stop working and probably blow a fuse??
I was thinking about this this morning after reading up on fitting a metal fuel tank. Surely the tank needs to be isolated from the body altogether?
Confused!
Edit: I must be miss understanding something about vehicle electrics as surely even if the tank wasn't earth bonded to the chassis the pump and senders positive and return would short when wetted by fuel. I remember having the same thoughts when I replaced an in tank fuel pump and my old car.
Edit!!!!
Oh petrol in non conductive ! Well that explains a lot!! haha! I thought all liquids conducted electricity! Doh!
Old 6th March 2013, 03:16 PM
Hi David,
and secondly.....
Surely if you earth the tank to the body when fuel causes a path of least resistance between the tank and the live wire in the tank the pump and/or sender will stop working and probably blowing a fuse or worse causing a spark in the tank??
Confused!
To install the send i used m4 ultra low profile rivnuts. I then used the rubber gasket of the sender unit that is quite thick and lots of sealant. Robo recommended some sealant that was made by 3m and resistant to almost everything. The sides of the sender were ground away slightly with an angle grinder so that I could get a flush fit.
As far as the earth goes the sender has its own earth that runs back through the cars electrics however I added another one to satisfy my IVA. The fuel pump still works with the earth attached. I think the tank is negatively earthed on an mx5.
Let me know if you find out otherwise...... (in case I blow my garage up by mistake)
Old 6th March 2013, 03:37 PM
Petrol has very little electrical conductivity. Consider that the fuel level sender is offen a bare resistance coil dipped right in the petrol and it doesnt affect it. Also given that the fuel is wrapped up in metal, the fuel its self will never be the path of least resistance. AFAIK most fuel tanks are earthed.
edit: Found this in a Fire Brigade, Fire Safety leaflet.
Petrol Engined Vehicles
Gasoline vapours contained within the fuel tanks of road vehicles are generally too rich to ignite. However, there is a zone near the tank filler cap, which may be in the flammable range when the cap is removed. During fuelling, flammable atmospheres may exist externally around the filler orifice. Therefore the possibility of an ignition from electrostatic discharge has to be considered.
The flow rates and hose diameters used at service stations are usually small enough to ensure that dangerous levels of static charge are not built up in either the vehicle's fuel tank (provided the design is such that it is not highly insulated from the vehicle body) or on the surface of the filling hose. There is the possibility however that an insulated conductor involved in the operation, such as the filling nozzle, the vehicle itself, an insulated filler neck on the vehicle tank, or the person doing the filling, could accumulate a static charge. Any of these could produce a spark in the flammable zone around the filling inlet and cause an ignition.
More than enough. Fuel pump and sender probably have their own ground feeds, this one is just to prevent static buildup on the tank.
