Old 28th February 2013, 09:31 PM
loony's Avatar
loony loony is offline
Update:
I changed steering wheel - 32cm Raid fits much better than OEM Sierra:
And column bearing on it's place:
I found old/new pedals ovarlay kit:
But - will it fit to the Roadster ? They are 6cm (clutch&brake pedal) and 5,5cm (gas pedal) wide...
Lucas
My build thread
Old 2nd March 2013, 05:48 PM
loony's Avatar
Saturday update:
I bought VAG starter motor for my electric reverse - another £10
It's a 0,9kW starter from 1,2/1,4 Polo/Fabia/Golf etc.
And I trial fit reverse gear to transmission tunnel - it's OK (as big as it can - 5mm clearance on both sides):
Lucas
My build thread
Old 2nd March 2013, 05:51 PM
loony's Avatar
Yesterday I picked up rear frame tubes, so ... it's time to weld chassis and move it forward:
And... now it's done - welded and moved forward to build rear frame:
Lucas
My build thread
Old 2nd March 2013, 06:47 PM
Good work Lucas, keep it up !
Old 2nd March 2013, 07:41 PM
maxubar maxubar is offline
Hi.
Where did you get that ring for the electric reverse? I'm currently searching for one or a drawing to have it cutted..
Thanks
Tiago
CBR1000F Powered Haynes Roadster
http://www.facebook.com/#!/album.php...0&id=771932872
Old 3rd March 2013, 05:33 PM
loony's Avatar
I draw one myself - DP12 72 teeth, 156mm diameter. Then it was laser cutted, but it's better to use waterjet instead of laser (too complex shape = too much heat).
Link: DP12 Z72 156mm.dxf
Lucas
My build thread
Old 16th March 2013, 09:05 PM
loony's Avatar
Today progress:
Lucas
My build thread
Old 16th March 2013, 09:06 PM
loony's Avatar
And some chassis plates...
Lucas
My build thread
Old 22nd March 2013, 08:29 PM
loony's Avatar
Another block in the roadster puzzle... after over week of waiting (Polish post office is a nightmare) I got my steering rack... for about £14
It's RHD Fiat Punto Mk2 PAS steering rack... TRW 37502372.
So as some of you realised it's FWD steering rack, so it wouldn't work. But, as I live in Poland and I building LHD car... and I will mount it upside down, everything will be OK (I hope).
Why this rack ? It's locost ? Yes, but... there's something else. Rack length (tie rod swivel center to swivel center) is about 530-540mm - better than Escort Mk2 rack, which is almost unavailable in Poland (almost, because you can always order it from UK, but it's not cheap). Maybe it's not "quick-rack" - about 2,7 lock-to-lock, but still better tha eg. Smart steering rack
Lucas
My build thread
Old 23rd March 2013, 11:29 PM
loony's Avatar
Busy day...
First - trial fit of steering rack:
I need different than book mounting plates (vertical), but it should be OK.
And back to welding:
Lucas
My build thread
