#491
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
#492
The stalks are only needed to get the indicators within 400mm of the edge of the vehicle.
If they were built into the headlights that wouldn't be a problem as the headlights need to be within 400mm of the side anyway. I suspect where they would fail IVA is with the headlight beam pattern, as presumably they 'kick' the wrong way with them being from the US. Still a nice idea though! |
#493
Davey fitted some all in one units. Not cheap but very neat venom 5, they have side light head/dip and indicator. I think the fronts only need to be visible from the front, the side indicators deal with vision from other angles.
![]() Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 18th February 2013 at 10:40 AM. |
#494
That's my mirrors fitted - one more thing ticked off the list
#495
Stupid question I suppose but how much fuel pipe did you use? Just ordering some now.
#496
If you mean the rubber pipes, I've no idea! |
#497
I see you have made a second black cover? Red one looks good, and my car will be red eventually. Do you sell the red one??
#498
I was running low on red vinyl, and chopped the red cover up the other night to make some more interior panels... |
#499
Speaking of interior panels, I've spent the last couple of days in front of the sewing machine making some more
Just finished fitting my seats and belts too: |
#500
Looks ace? What seats are those? There not your original seats are they??
