Old 10th March 2013, 10:04 AM
Tyco duraseal crimps are really good, but not cheap...
They're crimps covered in self adhesive heatshrink.
Soldering isn't generally advisable as the vibration can cause the solder joints to crack.
I have to admit I ended up making a load of solder joints when my stash of duraseal crimps ran out though
I'm sure I'll regret it at some point!
Old 10th March 2013, 12:32 PM
Wurth no longer do those solder sleeves,personally solder and heat shrink
Any joint that is not bright shiny solder is "Dry" and will cause problems.
Old 14th March 2013, 10:55 AM
brainbug007's Avatar
I just used loads of bullet connectors then taped them up. Cheap & effective in my opinion
