#26
![]() Hi David....I would be very surprised if any kind of solder would reach melting point on an exhaust tip, but I used silver solder because of its compatability with stainless steel ...trouble is you really need oxy/acet to get a good result or at least map gas, propane will work if torch is mixed with compressed air but not high pressure......a good flux is essential because the steel will readily oxidize....you know where I am if you need it doing.
Has to be a rolled tip for the IVA by the way |
