Old 10th April 2013, 01:44 PM
Default WARNING Escort track rod ends with mx5 front hubs.
At full droop on the suspension you will be stressing your steering components as there is little to no movement left in the ball joint due to the angle of the steering arm. Luckily I modified my front hubs so they would accept the taper of the escort rack and discovered this issue, resulting in a bent rack extension.
Anyone know of anyone making escort to mx5 extensions? Or a better solution!
Old 10th April 2013, 01:48 PM
At full droop on the suspension you will be stressing your steering components as there is little to no movement left in the ball joint due to the angle of the steering arm. Luckily a modified my front hubs so they would accept the taper of the escort rack and discovered this issue, resulting in a bent rack extension.
Phil at Talon makes them but theres a bit of a wait at the moment for obvious reasons.
Have I heard that people have reamed out and mounted the TRE from the top to get round this? Reaming would only leave you with 1/2 taper contact so again I think I read some peopl drilling out and putting in tapered inserts.
Old 10th April 2013, 01:50 PM
Cheers Stot I'll make enquires.
Old 10th April 2013, 01:52 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Maybe send phil a message may take a little while but he will do you them to whatever spec you need sure he will be along soon
Old 12th April 2013, 09:55 AM
Cheers, spoke with phil. Sorted now tks.
