Old 16th April 2013, 09:04 AM
Originally Posted by Dualist View Post
Will you be making a lot of these.??
Ha. CNC-ing them I could only do one for myself, I imagine the machine time for that would be 2 hours on my little rig but I work in a merchandising company so ill look into having a group buy on an enameled version. Only problem is I recon the minimum would be something like 100.
Old 16th April 2013, 01:44 PM
Put me down for two!
Btw hope your eyeball is better- been there too,a steady handed doc yanked it out
Old 17th April 2013, 08:35 PM
I went to A&E the night before I posted the pic and the doctor said he would "dig it out with a needle" which he did, but not before accidentally pricking my nose with said needle... I still let him do it.
It is a lot better now but was horrible for a couple of days.
I think I would need to get 50 badges at around a tenner each to be able to place an order.
Old 17th April 2013, 08:45 PM
Back to the dash again...
I made a 3rd incarnation of my dials to try and get a better colour in them and also wanted better light distribution so on ebay I got..
..a 5m length of 12V warm white LED strip and cost just £10 delivered. Bargain.
I planned to stick it around the inside of the dash like this as it has adhesive back. Nothing will stick to that white plastic the dash is made of so I ended up drilling holes around the outside and it will be held in by thin white zipties.
The light and colour is bang on now. I will be machining some individual dial surrounds that will block out all the excess light you can see around, as the electrical tape is doing here on the speedo and tacho.
Old 21st April 2013, 05:40 PM
Milestone.
Only on with threaded rod at the moment, and I need to weld in the front upper suspension mounts but it rolls to my other garage now.
Old 21st April 2013, 05:58 PM
Numplumb Numplumb is offline
Default Wishbones
Hi Stot been watching your build with interest and jealousy at how quick and cleaver you are, and what great ideas you have will be stealing some of them I think.
Question in your last photo it looks like your front bottom wishbones have a bend in them or is it just a camera angle?.
Regards Mick.
Old 21st April 2013, 06:37 PM
Hi Mick,
They do have a bend in them, they are Phil @ Talons design. The idea is to stop them fouling the steering rack at full steering lock and it certainly does that. There shouldn't be any real stress through the bend as most of the load will be at the two ends.
The front will sit lower once I get the proper mounts welded in.
Not sure about my rear shocks though. May need to send them back for some shorter ones. I ordered 14" Open 9.5 Closed which is fine for the front but I'm close to bump stop at the rear so may go for some 12" - 8.5"s
