  #26
Old 29th April 2013, 05:18 PM
Excellent new's Bob, thank you so much
I sent you an email with my post address, and you can reply by giving me the price you want and the shipment cost to Sweden.
I also just wanted to make sure that the round flange will fit the propshaft. The propshaft will come with the same flange that fits on the Sierra differential axle.
Size/register/PCD (holes are not equidistant) of the differential axle are as on the sketch below, so the flange should be the same.
Could you please confirm?
Thank you so much.
Attachment 1651
I have measured the transit flange and the register is 72.15mm and the pcd of the existing holes is 6 bolt @ 97mm. So with a simple ring made up the register can be reduced and it does look like the sierra prop pcd can be drilled on to it missing the transit holes. I will try to find a sierra flange just to make sure.
