Old 3rd July 2013, 09:48 PM
Numplumb Numplumb is offline
Pedal box looks good, I'm using mx5 pedals in mine too I have mocked it up and got the steering column over the rail and I'm using the bearing as NTS Saturn design, did you alter the loud pedal?.
I bent mine the other way and I think I will have to make it longer to clear the top of the servo, with it as Mazda made it I would not be able to get it to clear the side of the bonnet, I'm going to make a plate 280mm wide x 200mm high out of 3 plate and a frame of 20mm angle iron each side back to the steering column support and 30m x 3mm flat iron across to bolt the back of the pedals to and then make the top and sides in Ali back to the bulk head/fire wall when I make it.
