Old 6th July 2013, 07:18 PM
Busy day.
I got my brake lines secured in place.
I got the rest of my bits painted, including the rollbar.
And I got all my carpet pieces cut to size.
My build is not A-B-C more A-R-L-C but I figure that if I cant do the 'next' step in the build I may as well do 'a' step in the build rather than sit around.
Old 7th July 2013, 07:19 PM
Had a bbq with my family today and my dad kindly brought along his sewing machine so I can add some edging to areas of my carpet like down the trans tunnel and the top of the seat back.
I had a few practice runs to figure out the best way to do the edging.
Think I have a winner.
Old 8th July 2013, 08:08 AM
Unless I have missed the part where you said what the carpet was I would be using Marine carpet, otherwise it will start rotting and stinking from the first time it gets wet and it will get wet.
Old 8th July 2013, 09:06 AM
You're right Phil I didnt say but it is a rot proof carpet from these guys. Not the cheapest stuff but nice and should last some years.
Old 8th July 2013, 10:04 AM
do you use any backing or underlay or glue the carpet directly to the metal ?
Old 8th July 2013, 10:24 AM
I will be glueing direct to the metal on this one with a spray upholstery glue.
The edges of the trans tunnel will be trimmed with the leather and then use press studs to attach to the trans top so I can remove it easilly if I need access to the tunnel.
I used a felt underlay in my Jester but dont think I needed it, or need it for this car. If I were building a Cobra or the like I would felt for sure to give that extra plush feel.
Old 9th July 2013, 09:42 PM
Had more of a play with the sewing machine today.
I'm going to cover my interior side panels with leather and have a pelmet coming off the top of it over the top of the side panels to finish them.
Really happy with how the test went, the finished item should look smart.
