Old 21st July 2013, 01:39 PM
Ricky....Could have done that but by my reckoning you will only need to move it once after IVA so I will redrill and tap hole in mushy then.
Johno....yeah, cover plate is functional ...I made it that shape on purpose as it will act as a heat sink/soakaway to protect the f/glass at that closest point of exit....next up will be change water pump as there is a very slight leak so want to get it done before permanently fitting nose cone, then if everything underneath is ok it will be onto its wheels and will be sending IVA form off tomorrow
