![]() Quote:
![]() Cheers for that, when people use these bushes, are they getting breakages of the diff arms at all please ? I have ordered my gbs diff mounting kit which is coming in at a whopping £150, but with this bracket kit, you cut the arms off the diff completely. I don't know how this works exactly, because when I went on my tour of gbs, there was no diffs available to look at, which was a bit of a shame really. But, if your bushing at £35 pounds each ( if my conversion rate is right ? ) , will be a much better deal. I know you have to include shipping, but still would work out a lot cheaper.
![]() Looking good Struve. 1 thing I will suggest, where your nuts are at the bottom of the diff nose, id put a plate approx 25x75x5mm (1inch x 3 inch x 4g) with 2 holes in to take the nuts. It will spread any load over more of the diff, reducing the chance of cracking at the hole.
![]() They look good but I have already bought mine from Flow-Flex they are two pieces with crush tube like the top section of your ones ie flat that is why I was thinking of the large washer underneath because they don't dish in so I think that would be okay what do others think?.
Regards Mick. |
![]() That's what I was going to do with mine. Use the floflex bush and tube, and make a large 'washer' the same diameter as the bush, around 5mm thk. You could use a standard washer (as long as the washer is bigger than the crush tube) but I would like the look of a chunky one!
![]() Quote:
![]() Quote:
Are these designed to be used with the mounts that come on the MX5? The ones that sit under the diff arms? David
![]() No the replace those with those 2 big poly pieces and just reuse the big washers.
![]() 75mm x 5mm disc on eBay 2 off for around £5 and drill hole in centre is what I have decided to do with mine
![]() So are guys just using pressure to hold the bushing in then? Instead of something that extends beyond the bushing to catch the bottom side of the carrier.
