Old 16th August 2013, 09:34 AM
locost-turbo locost-turbo is offline
do u know what other vehicles it came in? or is it just ford? and if I use the t5 box which I see arent too expensive and find the cossie diff. is the prop and drive shafts the same throughout the sierra range? looking at flea bay, seems that anything with cosworth cost ten times more. is this because its all uprated? or just the name.
now need to work out if uprating a standard diff with lsd will be cheaper/stronger than a stardard cossie diff which I think already has the lsd built in.
thanks for your help. early stages. but want to have a plan of what I building and before I start tacking metal together.
