Old 16th August 2013, 09:52 AM
Originally Posted by locost-turbo View Post
rover 75 zzt has the t56. thats where my money is on gettong a cheaper box. (dreams of a 6 speed box rated at 450nm) not even pod would break it :0)
Rover 75 is FWD, only the V8 version was RWD and they are as rare as hens teeth.
Old 16th August 2013, 05:07 PM
some tvr's had a t5, cozzies had them
Old 16th August 2013, 08:45 PM
locost-turbo locost-turbo is offline
omg. seems the usa is the place to get them. seem common as muck. will be doing further research. but you can get them for 100usd. 70 pounds!. this could fund my build. wonder how many types of t5 there is. bonus is they are loads of gm patten which will fit straight onto the saab. will feed back.
Old 16th August 2013, 09:04 PM
Be careful on the gm patterns, they have about 5. There is a list and description somewhere on the Internet, but the one you need is something like European pattern.
I believe someone on UK Saabs has posted up links and explanations.
Old 16th August 2013, 09:12 PM
if I get a uk t5 I will need new bellhousing or adapter plate at minimum. but if I could get one that fits ill be quids in. just have to harrass my friend in the usaf. as they get stuff shipped over for free. not sure if he could stretch to a gearbox though. but worth a shot. not sure on ratios though. but I guess a v8 box should be strong enough for me. just need to get the right codes. seems to be several different t5's.
Old 16th August 2013, 09:21 PM
any idea on the t5 in the cossie? should start 1352 - *??
found all ratios. some have short bell housings (room for an ally plate to change bolt pattern) guess I just need to get a longer input shaft. but its gotta be cheaper than the uk prices.
