Old 16th August 2013, 12:20 PM
Short Short is offline
That's what I was going to do with mine. Use the floflex bush and tube, and make a large 'washer' the same diameter as the bush, around 5mm thk. You could use a standard washer (as long as the washer is bigger than the crush tube) but I would like the look of a chunky one!
