![]() The 1800 diff has a larger crownwheel and is physically bigger (might be a bit longer too). The 1600 and 1800 driveshafts are different, so if you fit a 1600 diff you will need 1600 driveshafts too. On MX5s, the prop must also match, but I don't know whether the prop length is the only difference and therefore not an issue on a Roadster.
Push in driveshafts will also fit bolt in diffs (at least for the 1800s, as I have this exact setup on my Torsen). |
![]() [silly ideas]
If you could machine down the bolting surfaces 6mm you could sandwich in the mounting plate to the standard diff. Or maybe you could design a plate that can be bolted on externally using the existing bolts that hold the diff together. Need to cut it around the casting webbing. ![]() Then cut the wings off. [/silly ideas] Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
![]() I did consider that at one point I even offered the cover up to the mill, then I had a little think about gripping a brittle ali casting in a machine vice....
![]() Just re read my gillham guide, and under the section differential, it actually has the nose braced. It says, an additional length on 19mm box can be fixed between BR12 & RS3, with a 5mm packer welded between RS3. The second engine mount rubber can be used to secure the front of the diff. I have revision 3 notes, so maybe it was not in the earlier build spec. Maybe we were all that keen, we missed it. 19mm box & 5mm plate it is ! ( picture in notes is - figure 41 : front lower diff mount position). Tidy on a Friday !
![]() Quote:
![]() Quote:
Clamp the jig to the table and then bolt the diff casing to the jig from above. I think the hole spacing is equal so if you do 2 opposite sides then turn it 90 degrees you could do the other 2 sides. Probably need to cut the wings off first too. At a push I could probably do this on my little Sieg SX3 in 8 steps with the head at 90 degrees. ![]() Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 Last edited by Stot : 30th August 2013 at 12:43 PM. |
