Old 1st September 2013, 04:33 PM
Also fitted my finished steering column.
Cleared up the wiring behind the dash So I can start mounting it up.
Old 1st September 2013, 04:34 PM
And had a general cleanup and take stock of the state of the build.
I haven't felt like I did much lately so glad to get that all done.
Old 1st September 2013, 05:39 PM
Oscar Oscar is offline
Looking very nice!
Don't know how you carry on with only one headlight, would really bug me not fitting the pair to match
That steering column end, does that UJ change from the sierra to the Escort size splines? If so, are they available on the open-market or a bespoke part by yourself? Looking for some way to replace the dodgy old rubber donut...
Photos of the project so far:
Old 1st September 2013, 06:13 PM
Originally Posted by Oscar View Post
Looking very nice!
I only put it there to get an idea on wing position but its on my to do soon list. I have to make a matching pair of risers and haven't got round to that yet.
The steering link is an escort spline at both ends. My steering gear is MX5 but you can buy column shafts from rally design and maybe remake your extension to get rid of the rubber donuts? Not sure I haven't played with a sierra build. They do do these though which is Sierra to Escort.
Old 7th September 2013, 06:07 PM
Had another play with my badge the past couple of days. I machined an aluminum one.
I first tried using gelcoat to colour it like my other badges but it doesn't stick to the aluminum and the colour came out in nice molded pieces. So I gave it an acid etch primer coat and went at it with some Humbrol enamel model paints.
The colour sits in there as I originally intended so as long as it dries nicely I should be able to sand the surface back to aluminum and polish it.
Old 7th September 2013, 06:15 PM
Actually Stot...I rather like the look of the plain machined version, bit o lacquer and it would look real techy
Old 8th September 2013, 01:55 PM
In context of a more modern build it could look cool.
Old 8th September 2013, 02:00 PM
I made up some windscreen brackets today. Made them out of the 1.5mm 5251 H22 which is what I used for on my floor. I think it should hold the windscreen fine but if it seems too flimsy when I fit it Ill get some 3mm.
A set for a full size screen.
And a set for the flyscreen.
All the scuttle mounting holes are in the same place so I can swap them around easy enough.
Old 14th September 2013, 06:16 PM
The model paint wouldn't dry in the end. A week later it was still wet I decided to 'cold enamel' it which is basically filling the voids with a coloured molding resin. That worked 100% better.
Ready for the nose then.
I have also been working on the bezels for the dials. I got some chrome bezels from ebay but they are designed to go behind the standard MX5 acrylic shield so I got some laser cut acrylic discs and glued them up with some clear setting epoxy.
Its turned out well so far but I'm waiting for the laser guy to properly cut me the leather so I can mount up my warning lights and finish making the center dash.
Old 15th September 2013, 10:39 AM
The LED bezels finish it off nicely.
Shame its going to be at least another week before I get the laser-ed leather to make it up properly without the pulling and wrinkles.
