Old 28th September 2013, 01:51 PM
Default Make cut in the diff. casing?
Hi,
When I installed my hand brake cable through CP13 last year, the hard sleeve was touching the diff. in a way I don't like (forcing it into a bend which does not look right). It also makes the tensioning ring of the hand brake cable very hard to turn.
2012-11-16_14-06-19 par Voucht71, sur Flickr
2012-11-16_14-06-09 par Voucht71, sur Flickr
I would like to make some cuts in the diff. casing to allow the cable to run straighter, and have a smoother bend.
I marked in black the spots where I would like to do the cuts.
2013-09-28_14-33-31 par Voucht71, sur Flickr
2013-09-28_14-34-26 par Voucht71, sur Flickr
What do you think. Do you see any problem it could cause to the diff. casing integrity?
All comments and opinions are welcome.
Thanks!
