Old 19th November 2013, 12:28 PM
Sperex was the paint to use,dont know if still available.
Old 22nd November 2013, 11:54 PM
raceral raceral is offline
A lot of high temp paint will only cure if brought up to temperature.
Shutting off early may have prevented that, so fire it up again and let it run and get hot.
It looks far worse than it really is.
Also everything else related to the engine will also be burning off, any oil protectorate left inside the exhaust pipes will also burn off, etc.
Some first time fire ups can be quite a smoke show but harmless, it will burn off and then your car will be fine.
It is normal the first time out.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Haynes Modified Super 7 3.4L V6
www.lotussuper7replica.com/
Old 24th November 2013, 12:50 PM
Heh! Just a plain stainless manifold of mine smoked like crazy during the first firing. http://youtu.be/NZDFKbk8q_A?t=1m
Old 1st December 2013, 04:11 PM
Just a small follow up on this thread.
The collector has stopped smoking after a while as expected. But 650°C paint is definitely not enough for a collector. The painting is starting to get off in small chips now... I will need to repaint the collector with a proper 1200°C paint as Mike said (if I can find that here, which is not sure...)
Thanks for the help and inputs
