  #24
Old 20th November 2013, 12:09 PM
Originally Posted by rpjg1975 View Post
If you are using a sierra donor I managed to get hold of an rs item that fitted the column Also doesn't move the wheel much closer. Don't know if that would work for your wheel?
I think it depends on the boss Russ.....I got an RS one of the bay and although it did fit the column its actual diameter was a little smaller and it would not fit over the horn contacts.....I was well miffed when I found out and that was why I went with the mod job
