Old 25th November 2013, 11:05 PM
adamv adamv is offline
I use a stanley knife to score in to the surface and because it's bright yellow it helps me find it again! Also by scoring the surface a dirty finger rubbed across it makes it a permanent fine black line which is much easier to see.
Hi pal i sent you an email regarding chassis glat pack did you make head na tail of it lol.
Old 26th November 2013, 12:14 AM
Also another question might sound stupid to most
lets take bar C for instance bottom cross rail.
my plans say over all length 32.4 with 80° mitre
so do i cut it to 32.4 then mitre th 80's either side or do i mitre 1 at 80 then 34.2 is the other end of the mitre
Hope someone understands that as reading back even im thinking wtf
Old 26th November 2013, 02:49 AM
Generally, the plans specify the outer dimensions. IOW you can cut the given tube square and then mitre the ends. It's easier to make a mitred cut from the outset, though, and because many tubes are paired, you can reuse the mitre on the remaining tube, too.
However, mate, have you got the right plans? Tube C? Sizes in inches? You must be looking at the Uncle Ron's book drawings, and you need the Chris Gibbs ones if you want to follow the SSC MX-5 guide. The Gibbs (Haynes Roadster) chassis is 4" longer, 2" wider and 1" higher than the Uncle Ron/Locost one. http://www.amazon.co.uk/Build-Your-O.../dp/1844253910
Old 26th November 2013, 08:03 AM
Lol in my hasty im doing it man tone to the mrs look love heres the plan for all i no i could be building a bus.
i got them off a web site all the plans say is book chassis good job i aint started hacking up steel only to find out later i built the wrong car.
ill order that book now iv ordered the haynes book with the black roadster on just hope they come before sat so i can make a start unless anyone here has a file drawing they can link me to
Old 26th November 2013, 09:40 AM
rpjg1975 rpjg1975 is offline
That is the build guide that ash gardiner did if memory serves. You want the thick hard back with a yellow roadster on the front to build to. That has all plans and dimensions in it as well.
May be wrong but sure I will be corrected if so
Russ
Old 26th November 2013, 12:21 PM
I am having a bit of resort with regards to the flat packs and the prices for both the Sierra (book spec) and the MX5 (TMXR) chassis flat packs.
