Old 7th January 2014, 01:53 PM
Wain Wain is offline
Default MX5 Hazard lights
I have a MK2 MX5 engine and loom. The head lights and side lights work but i cannot get the hazards to work.
All earth points are earthed. Fuse looks ok, but when hazard switch is pressed or indicator stalk is moved, there is nothing! not even a click from the flasher unit.
Any suggestions are appreciated.
Old 7th January 2014, 03:54 PM
Default hazard lights
Hi Wain,
Have you tried plugging in the instrument cluster. I know that with the NA version they won't work unless you plug this in.
Hope this helps..
Old 7th January 2014, 03:57 PM
Thank you for your reply. I do have the cluster plugged in, when the headlights are on the icon illuminates on the cluster, but the indicator icon does not illuminate when indicating.
Old 7th January 2014, 04:24 PM
there is an earth lead for the cluster which comes out of the loom near the connectors. is this part earthed?
Old 7th January 2014, 04:27 PM
All earth points that i have found are earthed, i am confident this point is one of them.
Old 7th January 2014, 07:34 PM
I think there are grounding points that need to be connected under the dash for the indicators to work. I can check when I get home.
