Old 10th January 2014, 12:36 PM
What year scorpio is it.
Over here the SCORPIO was the BUGEY from 1995 , pror to that it was the granada.
If it's the BUGEYE then it will be a 16V engine. The downpipe may be different and the inlet is most certainly different. It will also be runnign EEC-V engine management with the ford PATS immobilisers system
The Escort RS2000 loom and ECU can be adapted to run the scorpio 16v engine. though.
If it's a Granada then it probably has the same head gasket as yours but if it's running well then it would be worth it anyway.
You can then strip the old engien at your leisure to see whats up.
Rob
Old 10th January 2014, 12:50 PM
davidimurray's Avatar
Are you sure it was bled properly after the rad change? Could the block have had a big air lock in it and the thermostat opening has dumped it all into the block emptied the header tank. Refill and repeat 4 or 5 times to make sure you do really have water loss.
Old 10th January 2014, 01:13 PM
Enoch Enoch is offline
Looks like a new Pope has been elected
If you wanted to try a very quick bodge you could put a bottle of K seal in it. If you don't know k seal, it was developed for the Rover K series engine, which has a dirty habit of head gasket failure. In actual fact it's not always gasket failure and more to do with erosion of the head or top of the block. Some say liner slippage is the cause but K seal often does the trick. It's not massively expensive (about £7 a bottle over here) and may just help you get through your inspection without having to do an engine swap.
Best of luck with whatever way you go.
Dave.
Old 10th January 2014, 04:15 PM
Does anybody know you are out on your own ?
Drill a small hole in flange of thermostsat to allow air out,did this on the large amount of Rover h/g I have done in the last don't know how many years.
Old 11th January 2014, 10:02 AM
Thank you for the last replies.
Yes I thought about the Pope thingy too
I'm pretty sure I bled the water circuit properly, I always fill it with the top hose disconnected, and reconnect it when water starts to come out of it, as it is the highest point of the system, I think it was not the problem, but thanks for the input.
As I said, I want to avoid any repair, time and expense if I have to change the engine at one point anyway. I just no longer trust this engine, and I don't want it to become a bottomless well for my time and money. I still have more than two weeks before the inspection, and I think I have time to swap the engine before. Doing it after will be more paperwork, perhaps another inspection, so better to have the final engine before. But thanks for the tip Enoch :-)
TT, the Scorpio engine I might buy is a 8v DOHC for sure, it is from 1992. I would have loved to fit a 16v from a Scorpio or RS2000, not impossible as it is the same block, and it would have solve my under-bonnet clearance problems too. But I would have to change the exhaust manifold which is now adapted to my exhaust line, and buy the right ECU and engine loom. So I will keep it simple, and cheap for now.
Here is the info on the engine if you want to check. ("mileage is in "Swedish miles", which is not a mile, but 10km! So the engine is 150.000km)
http://en.bildelsbasen.se/index.php?...ost_id=8649700
The only difference I can see with mine, is that mine is a N9C and this one a N9D, but according to Wikipedia, they are the same. I will get pictures of the engine early next week, so I will be 100% sure.
Thank you very much for the help
Old 11th January 2014, 12:49 PM
It will have the old style gasket though unless it's been done already.
Old 12th January 2014, 09:39 PM
Ok, so now I'm confused, and not sure about anything
This week-end I have run the engine again. In spite of what I answered to Davidmurray, I thought afterwards that it might be worth to check: perhaps the cooling circuit was just not properly drained, and that is the reason why I had to add so much water after my first run. So I made several runs of the engine, 15 minutes, 30 minutes, 40 minutes and even 1 hour.
And know, I think that David might be actually right. So sorry David, and thanks, you gave me the will to investigate further.
Run after run,I had to refill the header tank with less and less water. 1L to 1.5L after the run on the video as already mentioned, then 750ml, then 250 ml, and after the 3 last runs, I haven't had to refill at all (of course, I checked the lever after collong down (2-3 hours after the run). And theses 3 last runs were respectively 20 minutes, 40 minutes, and more than one hour for the last one. It looks like I'm no longer loosing coolant.
So tonight, I removed the spark plugs and the rocker cover, to check. You can see on my pictures here
http://www.flickr.com/photos/9949833...7639704156803/
... that under the rocker cover, it is very clean, it is only oil, and it does not look to me like there is any trace of coolant in there.
There is also a video (I know the distribution plastic cover is cracked (that is where the engine is leaking oil) and I bought a non-cracked one second had a couple of months ago, so replaced it tonight, as the rocker cover was open)
You can also see the spark plugs, and none of them show the signs flyerncle described.
Yesterday, there was a bit of brownish thing floating at the surface of the coolant in the header tank, but as TT said, this old engine and the second had radiator I fitted were certainly dirty. And today, not at all, as you can (not easily ) see on the pictures.
But... there is still this white smoke at the beginning, when I start up the engine when its cold. It always last 3-4 minutes but not more. After than, exhaust gas are completely invisible. I would also like to say that the smoke looks not as thick as it was last week on the video, but perhaps it is just my imagination.
Is this white smoke really abnormal? If there was a problem with the head gasket or the cracks in the head, wouldn't the engine always emit this white smoke, until there is no more coolant to burn?
So I think I'm back to the starting point, and I don't know what to do
Any ideas ?
Thanks a lot.
Old 30th January 2014, 12:30 PM
snapper snapper is offline
Would suggest head gasket
When white smoke stops water level has dropped below gasket level
Eventually all water would go as it turned to steam
