Old 10th January 2014, 09:47 PM
Ah ha, I found my old build thread! Time to resurrect it.
My tax ran out on the 1st of January, and I won't bother re-taxing it until spring, so it's winter rebuild time.
I did have a list of things I wanted to improve, but seeing as it's been burning a litre of oil every 100 or so miles I'd better fix that first
Not 100% sure what's wrong, but googling suggests I probably need to replace my oil control rings.
Started tonight by unbolting various bits from the engine in preperation for removal.
Just need to decide whether to rebuild it, replace it with another 1.6, or replace it with something a little more potent.
Old 10th January 2014, 09:50 PM
Supercharger or turbo charger!
Old 10th January 2014, 10:05 PM
I've got a turbo, a spare manifold, and some bigger injectors sat under my desk at work as it happens
Don't want to stick it on an engine that's already burning silly amounts of oil though!
Old 10th January 2014, 10:22 PM
Sounds like a good plan. Have a look at the mx5s running in the ma5da cup. They manage 250bhp reliably from their 1600s
Old 10th January 2014, 10:47 PM
Ooooh I'm getting all excited!
Old 10th January 2014, 11:47 PM
loony's Avatar
loony loony is offline
I was always told that it's cheaper and better to swap engine to something bigger than turbocharging smaller engine...
But... I turbocharged my BMW with M50B25 6 cylinder engine I'm still glad I made it... with old Volvo 850T5 turbo, without lowering CR... great experience...
But... if your engine needs rebuild or similar it's easier to swap than rebuild and turbocharge it...
Lucas
My build thread
Old 11th January 2014, 01:06 AM
PorkChop PorkChop is offline
Eh?
Both Ma5da (when it was still running) and the BRSCC equivalent run near standard 1600s.
The torque equivalent of 250bhp would be about the limit for both the gearbox and the conrods. Plus I wouldn't want that much torque going through a 90-93 1600 diff, it will, more likely than not, break.
Personally, I'd rebuild rather than replace. The youngest 115bhp 1600 will be 21 years old after all. The chances of finding another engine needing some form of rebuild will be more likely.
Old 11th January 2014, 09:08 AM
Originally Posted by PorkChop View Post
Eh?
That's what I thought
I seem to recall they're only allowed a head skim and a bit of porting, and have to run on the standard ECU.
I'd be surprised if they got 150bhp, let alone 250!
My thoughts exactly! I can pick up a 1.6 for less than £100, but chances are it's going to need a load of work too.
The other option I was thinking of was sticking a 1.8l Mk2.5 lump in there (~150bhp standard).
That's going to be a fair bit of work though, and even those are 10 years old and starting to go bang now...
Old 11th January 2014, 09:37 AM
Got the races mixed up. I know a company caled AK Automotive who ran a 1.6 in the Northern Sports and Saloon Car Championship that had been tubocharged to 250 bhp. they have now put in a 2.0 turbocharged engine and it has 350bhp. the car they run in the Ma5da races car no 90 which is a different car.
