Old 12th January 2014, 08:50 PM
Numplumb Numplumb is offline
Thanks for that information, I will check it again it seems that I have another part on mine than you have in your pic maybe I don't need part.
And thanks also to you alga.
Regards Mick.
Old 12th January 2014, 09:18 PM
Ah, have you still got the funny brake bias thing attached?
I junked mine.
Old 12th January 2014, 09:34 PM
Two pipes coming around reservoir to a tee piece on a bracket and three pipes off it two slightly smaller than the other one is this not needed then, do you fit a bias part somewhere else or is one not needed? There's labels on mine saying front rear etc.
Regards Mick.
Old 12th January 2014, 09:55 PM
Yeah, that sounds like the brake bias valve.
It looked like it was going to be a pain to fit, so I got rid of it and stuck a mondeo valve in the rear line instead.
As it happens I failed IVA because my rear brakes were far too weak
I took the Mondeo valve out and replaced it with a bit of brake line and passed.
The rear brakes on the MX5 are a bit pants at the best of times, which is why I guess a bias valve isn't needed.
Old 12th January 2014, 10:03 PM
Cheers skov I will have to think about it a bit more because I'm using the MX5 pedals and maybe the servo.
Regards Mick.
