![]() Ah, have you still got the funny brake bias thing attached?
I junked mine. |
![]() Two pipes coming around reservoir to a tee piece on a bracket and three pipes off it two slightly smaller than the other one is this not needed then, do you fit a bias part somewhere else or is one not needed? There's labels on mine saying front rear etc.
Regards Mick. |
![]() Yeah, that sounds like the brake bias valve.
It looked like it was going to be a pain to fit, so I got rid of it and stuck a mondeo valve in the rear line instead. As it happens I failed IVA because my rear brakes were far too weak ![]() I took the Mondeo valve out and replaced it with a bit of brake line and passed. The rear brakes on the MX5 are a bit pants at the best of times, which is why I guess a bias valve isn't needed. |
![]() Cheers skov I will have to think about it a bit more because I'm using the MX5 pedals and maybe the servo.
Regards Mick. |
